주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
My Retina Screen is behaving erratically
The screen has a LOT of white lines crisscrossing the screen which de-mark individual pixels which make it quite unappealing to watch movies,etc.
Also when the mac starts up - sometimes (quite often) there is a green imprint in the middle of the screen that adds the colour green to every colour on the screen, but this goes after like about 5 minutes. If I view the screen from the sides I can clearly see the green imprint very clearly.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
To try to isolate the problem, hook it up to an external monitor and see if the issue persists.
Next, start up in Safe Mode (hold down the shift key on start up to see if it might be software related).
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Thanks for your quick reply, but I have checked and it seems to be a hardware fault.
Hook it up to an external monitor and see if the issue persists. If so the problem is with the GPU. If not then you go to the display.
hello, i think i may have the same problem. display is ok on safe mode, but if i boot it in a normal way i also have a white screen with criss cross thingy, i hook it up to an external monitor and also the same output. is there a way to replace the gpu? Thank you!
It it's OK in Safe mode it is likely a software problem. Run a good "Paid For" anti-virus program like Symantec first.
댓글 달기
답변을 추가하세요
Anshuman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 199
