주요 콘텐츠로 건너뛰기
The Polaroid Cube is a splash-resistant, shockproof, and mountable camera that takes 6 megapixel pictures and shoots videos in 720p or 1080p HD.
Why isn't my computer detecting the Cube?
My computer is not recognizing my Cube when I plug it in with the USB.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
Make sure there is an SD card installed in your Cube. The Cube will not work or be able to be detected without an SD card. Also make sure that your SD card is at least Class 10. Lower Class cards will cause performance issues. Check out the Troubleshooting Page for more information pertaining to your device.
이 답변이 도움이 되었나요?
점수 4
댓글 달기
FYI, Make sure you are using a USB Data Cable and not just a USB Charging cable.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks! That did the trick!
댓글 달기
답변을 추가하세요
heath lamkin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 9
전체 시간: 7,741
