주요 콘텐츠로 건너뛰기
7th gen iPod classic drive fit in a thick 6th gen classic?
Ive got a broken logic board 7th gen thin iPod classic 160gb and have just got hold of 6th gen thick iPod classic 160gb that crashes when in use which i think is the hard drive.
Can the thinner 7th gen hard drive fit into the thicker 6th generation classic? does it need some passing or something to not move about?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The hard drive will connect and work, but you would want to make sure it's secure. If it keeps moving around inside, it could fail prematurely. Some kind of foam or rubber padding should do the trick.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
thank you, ill try that if you think it will work fine. Shame I'm going thicker, but I prefer my chances with that rather than moving the gen 6 board into the thinner gen 6 case
댓글 달기
귀하의 답변을 추가하세요
Tim 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 320
