주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi P202는 Ryobi One+ 시리즈의 일부입니다. 이 모델은 18V 무선 1/2인치 드릴이며, 밝은 녹색과 회색으로 구성되어 있습니다. 드릴 상단에는 내장형 수평계와 2단 기어 변속 스위치가 있으며, 방향 전환 스위치, 자석 트레이, 드릴 비트 클립이 포함되어 있습니다.
Drill just stopped working
Brand new drill. Used it a handful of times. Just stopped working while I was using it. Charged both batteries and still does nothing. Never got wet or dropped.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
@evanqwer , Evan, faulty motor or switch probable, return to place of purchase for refund or exchange. Good luck.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
More than three years old and it was a gift. No reciept so can't take it back.
Evan, if drill looks brand NEW as you stated in your original question and the store still sells that exact model, talk nice to the store clerk in the tool dept. tell them it was a gift and see what they can do. Other wise you will have to take the drill apart and test the parts trigger, motor,etc to find the fault and order the replacement part if feasible. I will post a link for replacement parts and how to guide, check it out.
Ryobi P202
Will do. Thanks
댓글 달기
Do you have any lights etc when pressing trigger? Mine would do everything right with lights etc, however when trigger pressed it would hardly ever do anything.. found the problem was with the speed selector switch on top. When in pulled drill apart i found the selector switch makes contact with 2 metal tracks, these were really dirty.. after cleaning them it works perfect.. just be very careful pulling apart as there are a few small pieces that can come loose.
This was on a ryobi 18v
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
I have a Warrior cordless that just stopped. I turned the selector switch back an forth a few times. It works fine now. Thanh you for the info.
mr Edmonds & mr Walker just saved me $xx from buyin a new drill
hell yeah y'all rock
-mikey
댓글 달기
답변을 추가하세요
Evan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 53
전체 시간: 34,154
