주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.3GHz, 2.6GHz, 또는 2.7GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.7GHz).
561 질문 전체 보기
My rMBP doesnt increase fans automatically.
Even in CS:GO. Sensors seems ok. I did SMC reset. Also did clean install. I can increase fans manually. My rMBP is rMBP (Mid-2012) and os version is 10.12.1. You can watch here https://www.youtube.com/watch?v=vQdviYOW...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The fan control is kind of different on Retina MacBook Pros for some reason, the SMC waits a while until kicking in the fans to high gear to cool down the laptop properly. The temperature isn't being increased very high by the testing program you're running. MacBook Pros usually go up to 105 C before throttling - try running Furmark for a long time, and if the fans stay at ~2000RPM even if the processor temperature reads over 95, then you may have a SMC or fan controller problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Ali Celik 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 75
