주요 콘텐츠로 건너뛰기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
Replacement keyboard of a MacBook Air 13-inch mid-2011?
Hi
My shift key has stopped working and the service centres have recommended that I replace the key board.
Why is there no iFixit manual for keyboard replacement? Where can I purchase a replacement keyboard?
Cheers
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Best place to purchase the keyboard is from eBay for under £20. The keyboards on this model are stamped into the aluminium with rivets, so you have to pull the keyboard out, then pull out the rivets using a wire cutter. This will leave holes for you to secure the new keyboard with small screws (search "a1369 keyboard screws" on eBay". Before pulling the old keyboard out, plug in and test the new keyboard to make sure it works, and is a keyboard issue, since it could be caused by a damaged keyboard connector on the trackpad.
Just follow the guide on ifixit to remove the logic board. Then you have to remove the speakers by sliding a thin tool (painting knife) under them, do not pull out the speakers. Then remove the black keyboard backlight (depending on model), so you can access the keyboard. Remove the outer screws and then rip the keyboard out.
It is easy to mess up pulling the rivets out of the casing, you have to have a tight grip (not too tight, otherwise you will cut clean through the rivet), then tilt the wire cutter to pull it out. If it slips and damages the rivet, grip it again and rotate the rivet until you see the rivet starting to rotate, then you should be able to tilt and pull it out.
On Youtube, search "a1369 keyboard replacement", will be videos of people doing this.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
The suppliers on eBay I have used offer just the keyboards or the keyboards with screws.
That's right, some do offer it with the keyboards. I prefer to get them separate though from China, can get the keyboard for 10$ and screws are 1$ a bag of 50-60.
Reece, would you mind updating your profile so you lock it your user name and we can notify you in other questions with the @ sign. As far as I am aware none of us know how to repair the Retina displays yet and your expertise on this would be very welcome.
Sure just done this, feel free to contact me if you need any advice on these. Done all models other than the newest 13+15 models.
댓글 달기
답변을 추가하세요
Shahid Hussain 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 1,400
