주요 콘텐츠로 건너뛰기
Mac mini 제품군은 2005년 1월에 처음 소개되었습니다.
1251 질문 전체 보기
How do I make the plastic rear-panel snap into the aluminium top?
(Mac mini generation 1 - 4; Early 2005 - Late 2009)
I have seen many Mac mins that have been opened. When people put back the top housing, they bent the rear plate so that the plastic no longer snaps into the aluminium top, leaving a small gap and a slightly bent plastic part.
Is there any chance to fix this and get back the original look?
Here is an image for comparison: the two Mac minis on top are fine, the other Mini has the gap I mean.
http://guide-images.ifixit.net/igi/yj4Ru...
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Yeah, hate the gaposis thing.
The usual way to open a Mini is with a cheap, thin, plastic putty knife.
You flip the Mini upside down onto a clean soft surface. I use a corrugated plastic roadside sign.
After pressing the putty knife into the gap between the base and left and right sides, you should hear horrific cracking and popping.
And this is where the problem lies.
You are bending plastic clips to release their grab on the case.
Check the clips for signs of strain. Sometimes you can shield the innards of the Mini with cardboard and heat the clips, especially towards the back end, with a 1500 watt hair dryer.
After they are hot, shim them slightly outward with cardboard and let them cool.
Then reassemble. This fixes the gap about one in three times.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
+ Wow, you're quite the font of knowledge. I've never heard of the word gaposis before.
댓글 달기
귀하의 답변을 추가하세요
Sven Harmstorf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 721
