주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
after screen replacement the iPhone screen will not turn on
i work in a repair shop and have recently been working on a iphone another shop worked on. they replaced the screen but some how they put in a old battery by mistake during the instillation. We replaced the battery and the screen immediately died. we have replaced the battery with 3 different ones and we have also replaced the screen with two different ones. itunes is picking up the device but the screen will not turn on.
do any of you have any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개:
Any signs of liquid damage inside the phone particularly near the screen connector area of the logic board?
Have you also tried another charging port assembly / flex (a.k.a charging dock) on the phone?
no liquid damage and we have not tried another charging port assembly.
when you say "We replaced the battery and the screen immediately died", can you explain a bit more?
Have you tried another screen to make sure the screen is not at fault?
댓글 달기
답변 1개
Did the back light driver go bad by any chance? Was the battery disconnected before the screen was removed and or when both were re-installed? If you do board-level repairs, it could be a filter problem, IC issue, resistor burnt out, coil damage etc.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Joshua Soukoreff 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 45
