주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
Is my machine motion sensitive?
I picked my iMac up a few cm above the desk it sits upon and tilted it a few degrees in all three dimensions and it shut itself off. I am certain that the power cord did not become temporarily disconnected. Other than the power cord the only other peripheral connected was the wired apple keyboard with the wired apple attached. No connections are/were loose. My computer has never sustained any physical damage. It has not shut itself off since, but I have not tried to reproduce the situation since it results in a hard power off. Is this model of the iMac designed to react this way during this situation?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
You mean
Like this?
Yes there are SMS (sudden motion sensors) on Intel iMacs - but moving any running computer is still an excellent way to destroy a HD.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You iMac should not be motion sensitive. You may have moved some component when moving it. If you do it again I would shut down first.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
xanthus702 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 891
