You may want to remove either the keyboard or the lower case to access the display signal connector. I can't say with confidence which one, but I'm going to guess lower case. Use a #0 Phillips screwdriver to remove the screws from the bottom of the laptop, keeping track of where each one goes and how long the individual screws. The display signal connector is a long, flat connector, and it often has a dull, woven wrap around the individual wires to protect them as it snakes into the display.
Again, I'm not sure if your laptop has a ZIF connector or a standard insertion force connector, so I'll detail both.
If you have a ZIF connector, use a spudger to lift the release mechanism, and the cable should come out with little to no resistance. When reinstalling the cable, make sure that you lift the release mechanism before sliding it in, then lock it in place.
If you have a standard insertion force connector (almost like a block connector, except it's way smaller), then wiggle the connector loose; be careful not to separate the connector block from the wires as you're pulling. You shouldn't have to force it, but you'll need to apply some pressure to pull it out.
댓글 7개
@skimmilk05 you may want to reconsider your spam vote on the above comment. @jimfixer is only pointing out that this is a student question so that we allow other students to answer this. There is no spam or offense involved. Follow the statement you've made on your about page "Unless you're deliberately trying to harm others with your ignorance. "
oldturkey03 의
@skimmilk05 , @joshw , @bearl , @benjamen50 excuse me if I offended you with my comment . It was not my intent to belittle or offend anyone only inform that this was a student asking a fictitious question . This way others know to leave the question for the students to answer . I have asked on meta that some sort of notification be put on these questions so we would know to not answer them . Some students have actually started putting there school logo on their icon . Once again sorry did not mean to offend and have removed the comment
Jimfixer 의
@jimfixer @skimmilk05 , @joshw , @bearl , @benjamen50 no way could this have been taken as spam/offensive and should never have been marked as such!
oldturkey03 의
This may sound stupid but honestly I voted yes because you guys voted yes.
Ben 의
@oldturkey03 Sorry when I reread the comment misunderstood the poll.
Claes 의
댓글 2개 더보기
