주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Boot loop and keeps turning on
Hello,
Yesterday I asked a question on ifixit, read that first.
Okay, so now, it won't turn off. Even when the battery died, it showed the plug in to charger screen over and over and over again until the battery really died. Now it is completely no power, but haven't tried charging it yet tho. Other than that it works. Haven't restored it yet, I get error 4013 on 2 different pcs. halp plz
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Update: the phone works again. Showing the restore screen and is charging. Maybe a shorted cap between the power button line and ground?
댓글 달기
답변 1개
This is why I run away from water damaged phones. The problem is that you fix one thing and then a new problem pops up. You can keep repeating the process over and over.
Its safe to assume the logic board has suffered severe damage. For sure on the charging system but it sounds like the touch system as well.
At some point you have to know when to stop. That's a decision that you make and only you. But your next step is going to involve replacing ICs if you do continue. And again...I promise that won't be the end of the repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gigabit87898 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 80
