주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Get the digitizer assemply with or without the home button et.al.?
I will rplace the digitizer/screen on an iP5 and an iP6. (have done this for other phones)
Wondering if the extra $$ for the kit with the button, earpiece etc is worth it, there are no problems with the existing button etc.
Also, I have not yet identified the specific models of the iPhones 5/6 I am working with (although I think each is the plain version, hints about how to do that with certainty would be appreciated.
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Whether or not its worth it depends on how much experience you have with iPhone repairs. Remember that iPhone 6 has Touch Id home button that is married to the logic board, meaning that if you were to order a fully assembled lcd with a button and just install it as it came - you will forever lose the Touch Id function. Although if you aren't comfortable changing lcd shield and the front camera, proximity, ambient light sensor flex and installing the earpiece, it may be worth it to order the full assembly and switch the iPhone 6's home button. Personally, it wouldn't be worth a penny to me nowadays but on my first and second iPhone screen repair it might have!
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
As far as how to do it - make sure you line up every screw exactly how you took it out step by step, you don't want to drive a screw too far into the wrong hole. Take your time and follow iFixit's guide. You can do it!
Got the assy w/ot the the button. Touch ID Lives. After doing an iP4, the 5 was real easy. Working on a water damaged 6 now. If I can revive it I will replace the screen similarly, swapping in the old button.
댓글 달기
귀하의 답변을 추가하세요
Gary Tash 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 43
