주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
a1549 won't register with any network
I have one that is stumping me. iPhone 6, a1549, won't register on any network no matter what SIM I use. Tried using a VZW, ATT and Sprint SIM and it wouldn't activate. Popped in a Tmo SIM and it activated. OK...so its a Tmo. I pop a Tmo SIM in with active service and it won't register on the network. Tried rebooting, reinstalling, banging it on the counter, all the usual steps.
What am I missing here? The phone works, the SIM works. I'm half tempted to believe that the phone is locked to some weird network but when I run it through our unlock service, its already unlocked.
HALP?
And just like that...it works. I didn't do anything to it other than open it to see if I could see anything.
I really do hate iPhones.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 5개
Hmmm....ran a cellular network test app and the phone isn't seeing any cellular networks. SIM registers just fine, IMEI shows up.
This is an odd nugget.
Hi,
Know nothing about iPhones but thought this may be of interest to you.
iPhone 6 cellular antenna location/replacement
Expand the comments above the chosen solution for more info.
Thanks. I'm not leaning towards anything hardware on this one.
Have you checked that it does have the correct time and date????
Yea...even toggled auto update and rebooted.
IMEI check came back and its for sure Tmo locked. Sooooo.....looks like it might be hardware.
댓글 달기
답변 1개
가장 유용한 답변
Don't rule out hardware. Loss of cellular connection is obnoxiously common on the i6. The antenna switch l
(rf5159) has gone out on a few phones I've seen. Any of the antenna connections could be loose or there is some kind of debris between them. Has the phone been disabled and reassembled before?
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Never been taken apart, which was why I was trying to eliminate software first. I think I've done that.
Thanks for that part number. Looks like an easy enough swap.
댓글 달기
귀하의 답변을 추가하세요
Josh W 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 6
30일 전: 6
전체 시간: 194
