주요 콘텐츠로 건너뛰기
The 2008-2012 Ford Escape features a revised front and rear fascia and restyled LED tail lamps.
50 질문 전체 보기
Wierd smell coming from heater
No matter the air temperature or fan speed, there's some bad smell coming from the vents whenever I have my heater on. It kind of smells like burning plastic, but not that bad, and I haven't seen any indication of melting or burning anywhere else, but I haven't looked deep and thoroughly yet. I'm guessing it's just the air filter that needs replacing, but might it be the heating element or something?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Always start simple and the air filter is simple.
https://www.youtube.com/watch?v=fJuPcWuO...
There's a fun video to show how bad they can get, even in a well maintained car. He has another one where he pulls out half a sweater's worth of fuzz from under the hood as well.
댓글 달기
답변 3개
선택된 답변
@chrishnaw , Christian, Ford Escape mildew/musty smell from vents would be common sign of moisture/debri/dust build up in lower HVAC duct work, uasually caused when the drain tube for AC plugs. If the heater core is leaking coolant and you put it on defrost you will notice the windshield gets a film/residue over it or you will notice the coolant dripping from the heater/HVAC box/ductwork, etc. onto the carpet, you can have the cooling system pressure teted to verify leak or not. A burning smell could be a sign of faulty heater resistor, wire/plug melting, or the blower motor burning out and should be checked sooner then later.1st Link below will show how to access the wires and resistor to the heater motor. 2nd link will show cabin filter replacement. Good luck.
https://www.youtube.com/watch?v=zLtPIUjs...
https://www.youtube.com/watch?v=EK4cyKS_...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
You know what I don’t like about Ford. It’s their insulator, it’s emitting a foul smell. Go ahead take a piece and sniff it. It is located under the carpet flooring, it is also inside the door casings. The solution for this is to have your dashboard pulled down, remove all the insulators from Ford and replace it all with a different brand of thermal insulator. After this have your interior detailed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I recently bought in the 2015 Ford Escape SE and I thoughtmaybe the previous owner had dropped something down the vents because there's a smell coming out of the air conditioning/heater vents (and more so when the heat is on)that I cannot seem to get rid of. Could this be what I'm smelling. It's almost like a raunchy ashtray
댓글 달기
Most likely heater risistor that needs replacing or has been replaced previously by a cheaper none genuine
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Christian Stout 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 47
전체 시간: 24,578
