주요 콘텐츠로 건너뛰기
Model A1224 / Mid 2007 및 Early 2008 / 2, 2.4, 또는 2.66 GHz Core 2 Duo 프로세서
548 질문 전체 보기
Will only boot to the folder with question mark
My first Imac will only boot to the folder with question mark. I bought a second and similar imac and changed the hard drives but this first one will still not boot with the new hard drive. However on the second Imac both hard drives will boot
What could be the problem with the first Imac?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
A folder with a question mark means the computer cannot find a start-up folder. If you are getting this, it's not booting correctly. If the computer eventually boots, go to the System Preferences and select the start-up drive you want it to boot from. If it fails to boot at all then boot from your system installation DVD and go to the second screen pull down menu to Utilities -> Disk Utility and see if it will see the hard drive. If it does try repairing it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Cable
or connector... more serious (logic board) problem if there was an electrical spike to the first one.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Francis Obi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 1,862
