Thermal pads dimensions for gpu and others
Hi. I need dimensions of thermal pads in GPU and others in this notebook
좋은 질문 입니까?
좋은 질문 입니까?
HI: You are either thinking about taking your computer apart or have a gpu warning about over heating. I have built many computers and prefer using thermal paste. I do not like the pads. So the size of the pad is not necessary , get a small syringe of thermal compound and use a light approach to the compound. You want as much cooler to gpu contact. The compound is to bridge the gaps in the two surfaces not to actually butter the surface but to lightly smear. If you can rub the two surfaces together a bit and see how your smear is doing, wipe off excess, less is better.
Good luck, did not give you a dimension but the reason is I do not like the pads.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 14
전체 시간: 576
