주요 콘텐츠로 건너뛰기
Unveiled at the 2000 North American International Auto Show on January 10, 2000, the redesigned 2001 Dodge Caravan and 2001 Chrysler Town & Country were released for sale in August 2000.
Horn beeps at vibration/noise.
When our '07 Dodge Caravan is parked with engine off, vibrations or sounds trigger a "beep" from the horn. Is there a way to adjust or "dial back" the sensitivity or a way to disconnect the motion sensor(s)?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
@mr_fixit104 ,john, check that all door/hood lock contacts are aligned and clean, I believe if dirty/poor contact or not aligned vibration could set alarm off. From your manual,Security System Manual Override, the system will not arm if you lock the doors using the manual door lock plunger. The dealer may be able to change settings on the alarm. Link below is your manual, alarm section starts on pg. 18. Good luck.
http://cdn.dealereprocess.com/cdn/servic...
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
john 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 79
