주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2015년 3월에 처음 출시된 3세대 HTC One 스마트폰입니다. M8 디자인에서 크게 개선된 점으로는 옥타코어 Snapdragon 810 프로세서와 2000만 화소 후면 카메라가 있습니다.
HTC One M9 in weird boot loop
I have an HTC One M9 that is being super weird. Its stuck in what looks like fastboot mode and reboots every minute or so. OK..no big deal. It looks like someone tried flashing a custom recovery and failed. When I go to recovery mode or download mode, I get "failed to boot to X mode".
Figured ok, I'll check things out in ADB. ADB doesn't list it as being seen and I can't send any commands to it. I would write it off right there except that when I run a logcat and reboot the phone, ADB sees the phone disconnect. So the phone is communicating with ADB on some level, ADB just doesn't detect it.
I'm much more comfortable with Samsung boot issues. Anyone know anything about HTC?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 6개
Rip HTC one m9
Not rip quite yet. Firmware most likely needs reflashing because I unbricked an m9 before.
How do I flash the thing?
It's a bit complicated you need to use and to push the update file. When I get home I'll give you the steps. Its like copying an update.zip file to sd card. The problem is that the model number and other id needs to match.
yea...tried adb push but adb doesn't see the phone
댓글 1개 더보기
댓글 달기
답변 2개
선택된 해법
Not to sure on flashing HTC like you I'm more familiar with Samsung . This may help though good luck
이 답변이 도움이 되었나요?
점수 4
댓글 달기
I just went through this with my M9 and it looks like the linked Youtube video is down. :/
[For this, I'm assuming the phone is S-On and the bootloader is locked. It also assumes that the eMMC chip hasn't hit it's End-of-Life and died]
The answer starts off with getting the right aosd.img for the phone. Then, with the phone in fastboot mode and connected to the PC:
Type "fastboot flash aosd aosd.img" and press Enter. This will give you back Download Mode. From there, the choices are:
If the bootloader is OK, you can boot the phone into Download Mode and try to re-flash the firmware using the official RUU .exe. [If the bootloader isn't OK, the phone may go into a reboot loop: To break the loop, hold the Power and Volume Up buttons]
If you are unsure of the bootloader, you can try reflashing the phone by putting the RUU .zip file onto a micro SD card and flashing from Download Mode.
The worst case scenarios I've seen so far are:
If the phone cannot be reloaded via the RUU and you're stuck S-On, you can use an XTC2Clip to go S-Off and reflash the firmware.
The eMMC has exceeded it's life cycle and gone completely corrupt and unrecoverable. At that point, the mainboard would need to be replaced or the original board would need to be reworked to put on a new eMMC chip (iirc, a new chip is ~$5. The main cost is having a reball setup and proper jig).
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Just switch off the location and the problem is solved
댓글 달기
답변을 추가하세요
Josh W 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 49
전체 시간: 5,421
