were is the crankshaft sensor located
i have a 1999 plymouth voyger2.4l dohc i cant locate the crankshaft sensor
좋은 질문 입니까?
좋은 질문 입니까?
Chrysler 2.4 crankshaft position sensor is bolted in lower engine block, behind the engine (engine side facing the vehicle's firewall) look above the oil filter adapter from under car. Crank sensor held/secured by a bolt, remove bolt and sensor will come out with a little pull/twist force. Links below show the location and how to test crank sensor. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 14
30일 전: 62
전체 시간: 5,622
