주요 콘텐츠로 건너뛰기
Does anyone know how to get the data out?
Hi, I have made a back up of a Samsung J5 and I require the data in a more universal format, specifically the contacts. At the moment they are in a .spba format and I was hoping I could get them in a .csv or similar format. Does anyone know of any apps that will let me read and export this data, The calendar would also be helpful.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
I just tried a few tricks and they all failed. Google failed too.
The easiest thing would probably be to upload them to another samsung phone, then sync contacts and calendar with Google. Then you would have access to them from any browser.
Would be nice to have a program that I could just read the data, if I had their new phone I'd just use smartswitch to restore the data to the new device.
Utilité:
Ecran planté => on ne peut plus accéder à l'appareil (on ne peut pas le déverrouiller, on ne peut même pas l'éteindre, il n'y a plus que la sauvegarde faite il y a 3 semaines avec SmartSwitch, tous les fichiers sont là, sur un PC, ils sont même dupliqués par sécurité.
Après recherches:
.spba est une version chiffrée de .spb, spécifique à l'appareil, donc inutilisable pour restaurer un portable non Samsung (j'ai renoncé à la marque, trop chère)
Les boules : plus aucun contact alors que j'avais 2 sauvegardes, c'est en principe de l'Androïd, pas spécifiquement du Samsung.
NOTE; THIS PROBLEM IS NOT SOLVED.
Même s
댓글 달기
답변 3개
선택된 답변
Ok I found the answer to my question. Use the original Samsung Kies (Kies 3 doesn't work). It will let you read the .spba file and save it as .vcf or .csv. Too easy, Thanks for the effort.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I've yet to try the calendar but will post back here with what I find.
Won't do the calendar, not as important so am leaving for now, but if anyone works it out it would be good to know for future use.
댓글 달기
Will you please clarify which version of Samsung Kies you used? I have tried 4 versions already without sucesss
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Kies 3 is the version I used to read the contacts file. You may need to use the latest version or even smart switch to make the back up but depends on the device.
댓글 달기
Which version did you use ? please share the link if possible ..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Hortman 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 11
전체 시간: 11,601
