주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1.5 Core Solo, 1.66 또는 1.83 Core Duo, 또는 1.83 또는 2 GHz Core 2 Duo 프로세서. 이 내용은 2006년 초부터 2007년 중반까지의 최초 Intel 기반 Mac Mini 모델을 다룹니다.
Anyone found an alternative Mac Mini outer casing?
Hi! I recently acquired a 100% functional Mac Mini from a recycler, the only catch being that the outer casing has been destroyed, and so the guts of the Mini are exposed, and it's not really in re-saleable condition. I've looked into replacing the casing, but it seems a little silly to spend $50-$100 that people are asking.
Does anyone have thoughts on a practical alternative to Apple's Mini case? I'd prefer something on the practical/discreet side, as opposed to goofy and outrageous.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
If you end up with it in the cube case or the floppy disk drive, you should take some pics and link them here so we can take a look at what you did.
의
댓글 달기
답변 4개
선택된 해법
How about a nice ammo box. Lay it on its side, cut the top for the CD drive. Larger boxes could be used for extra hard drives. Comes with a carrying handle.
http://www.amazon.com/Military-Ammo-Wate...
For a bigger box, use the 50 cal version: http://www.amazon.com/Military-Surplus-C...
Here's a bunch of various goodies: http://www.colemans.com/ammocan.htm
Consider using the dome from a iMac G4 with out the screen attached.
이 답변이 도움이 되었나요?
점수 3
댓글 6개:
Or an old mac cube case would be awesome! but the little research I did I couldn't really find one for much less than $50.
의
Awesome idea Mayer! I'm going to seriously consider it...my only concern is that the metal might keep wireless from working, but I'm sure there are ways around that.
R Trent, thanks for the idea...I have an old Cube around, so I'll see if it fits...that would potentially be a fairly easy solution.
의
good answer +
의
Yeah WL might be an issue- also it'd add a TON of weight, probably not good for ventilation either though, do you have a CNC machine?
의
The cube's a great idea- in fact, it's upgrading the Cube so you get some sort of Mac Cube? Cube Mini? Whose origins cross processors and years.
의
댓글 1개 더보기
댓글 달기
Here is one that mayer came up with on Meta that I really like.
http://www.pcworld.com/article/170973/co...
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Oh wow, that is amazing!!! I just finished putting it into a Cube case, but I think I'm going to buy an Apple floppy drive on eBay now, cuz that's just too cool to not try! :-) Thanks!
의
+ I forgot about that one. It's good.
의
댓글 달기
How about buying a cheap generic mini-pc case? You can also often get those with a built in power supply, which is useful.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
For example, a quick eBay search turned this up, I'm sure you could get much cheaper with more thorough searching, and for Used as opposed to New parts
의
Great idea Rab! I'll take a look.
의
댓글 달기
Duct Tape
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I like the idea, but wouldn't that run the risk of making the computer overheat?
의
댓글 달기
답변을 추가하세요
rdklinc 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 21
지난 30일: 33
전체 시간: 4,829
