polorid flatscreen tv fadeing
how do i fix my poloid flatscreen. it starts to fade to white seconds after i turn it on
좋은 질문 입니까?
좋은 질문 입니까?
Often times, the capacitors in monitors and TV's that are in the power supply will go bad and cause the display to act up as soon as they have time to charge. If you take apart the TV and look at the capacitors (Probably the tallest cylindrical component) and see that they have a slight or large bulge in the top of them that means they are bad. In that case read the numbers on the side of the bad ones and replace them with an equal or greater valued capacitor. The metal part on the top of the capacitors should be completely flat.
Hope this works.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 36
댓글 1개
@lilms650 what model is your TV? What have you checked? remove the back of the TV and post plenty of good images of the boards with your question. it will allow us to see what you see and help you further. Use this guide 기존 질문에 이미지 추가하기 for that.
oldturkey03 의
