주요 콘텐츠로 건너뛰기
저렴한 Samsung Galaxy A3 스마트폰 2016 버전. (모델 번호: A310F).
59 질문 전체 보기
Wifi Modul Dual Band 5 Ghz
Hello,
i look for a Wifi Modul Dual Band 5 Ghz, because my Samsung support only 2,4 Ghz but my Fritz Box 7270 V3 support both 2,4 and 5 Ghz.
Who can help me to find out this Modul and maybe also replacement?
Thanks for Help / Support
regards Ron
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 2개
Hello, what do you mean by Wifi Modul?
I never thought Samsung would put out a phone in 2016, that couldn't use dual bandwidths. I have just started with Virgin. However, my speed test was below 4mbs,
댓글 달기
답변 1개
선택된 답변
You are right this Samsung Model only supports 2.4 GHz Wifi frequencies according to GSMarena and Samsung phone specifications on samsung website as well.
It's not a simple as replacing a module. The firmware would need to be reprogrammed and re-coded for it to work including the phone kernel as well.
Even if this was feasible it would cost well more than the phone itself probably more than double the price to do.
The Wi-Fi chips on samsung phones are BGA mounted (ball grid array) meaning that they are soldered onto the board by being soldered on sitting on solder balls that are soldered onto circuit pads on the motherboard.
Not a easy thing to replace as it will require board level micro soldering and a lot of heat including a microscope.
TL-DR / Short Description answer: No not possible or feasible realistically.
I guess what we learn here is to always look at the phone specifications listed online via the manufacturer's website before buying the product if you are going to use certain features that most cheaper phones will not have.
해당 답변은 도움이 되었습니까?
점수 5
댓글 달기
귀하의 답변을 추가하세요
Ron 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 10,503
