주요 콘텐츠로 건너뛰기
Nintendo DSi는 닌텐도 DS 라인의 세 번째 시리즈이며, 2008년 말 일본에서 첫 선을 보였습니다.
How to clean the slot for the game card?
The DSI won't read games, so I thought that it might be the slot, and I don't know how to clean it properly. Please help. Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
First, you should take a flashlight or bring the device under some bright light and inspect all the contact points to see if there are any issues (bent contacts, broken contacts, anything that looks out of place).
If everything seems to look okay you can try cleaning the slots gently with a little bit of rubbing alcohol. Usually it's best to use a small q-tip but if the slot is really skinny you can always try a bit of folded up paper towel, etc.
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
The q tip didnt fit, should i use a nail file?
Is there a way to do it without rubbing alcohol? We don’t own any
And I’m not entirely sure what the dry stuff in the slot is
댓글 달기
Do NOT use Q-tip.
Don’t repeat my mistake.
Unlike Ethernet connector, where the contact wires only expose their middle, in the reader in the Switch the contacts’ ends are loose. See the picture.
What a bad design decision.
As a result, if you push Q-tip behind the contact end, and then try to pull it back, the fibers will tangle with the contacts, and when you pull it back, you will BEND the contacts.
They are not easy to access and straighten, and you will end up replacing the whole card reader block for $40-$60.
P.S. the contacts are gilded, so no need to clean them from oxidation. You need an extensive amount of dirt on the card to make them dirty enough to require cleaning.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had this same issue and one of my pins broke off so I had to replace the card slot. It was a very difficult job for me soldering all those individual pins. But if your good at it might be worth it.
https://www.amazon.com/gp/product/B004ZT...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kdcao1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 18
지난 30일: 54
전체 시간: 22,108
