How to connect tablet to TV
What type of cable is needed to connect the tablet to a TV? HMDI from tablet to TV results in "signal not found". (Yes, the TV is set to HMDI for input). Thank you for your help.
좋은 질문입니까?
좋은 질문입니까?
Are you using the HDMI port on the device itself? It could be a Micro or Mini HDMI.
이 답변이 도움이 되었나요?
Yes HDMI cord w mini adapter connected to rca tablet ,TV screen says " no device found" , what other options are there
On your RCA tablet go to settings, click on display and then configure HDMI settings.
이 답변이 도움이 되었나요?
What do you do after or even how do you configure HDMI settings
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 13,203
댓글 6개
I am using the HDMI port on both the TV and tablet. Tablet takes a mini.
boogityboo 의
I now have it working. Started it with the keyboard attached, then removed the keyboard. Thanks for the help.
boogityboo 의
cant get it to work either way.what to do ?
Wess Reddish 의
I am having the same problem, HDMI cable is connected but tv says no signal. Did you find a soloution?
jillherbert1 의
I've got it working, see my answer below.
jillherbert1 의
댓글 1개 더보기
