주요 콘텐츠로 건너뛰기
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 질문 전체 보기
PS3 HDMI Port Failing?
I was using the YouTube app on my PS3. Once I exited the app the screen briefly flashed to a static screen then remained black, while still showing green 'power on' light.
I turned off the TV and reset the PS3. PS3 dashboard was with normal video and sound.
Just curious if this is a precursor to a failing HDMI port on the PS3 or TV, or a failing HDMI cable. I'm using a VIZIO HDTV and a VIZIO HDMI cable.
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi Chelsey Cain, don't do all the things which you can find in the internet like hold down power 3 and 5 sec, changing cable, changing hard disk...etc. believe me it won't work. and more over it may currept your ps3
1. Hold down power 2 sec to reset VGA (in 5 percent it will work if not all below will be fail only)
2. Changing cables (not work)
3. Formatting, Hard Reset PSR (not work)
4. Changing Hard Disk (not work)
5. Trying to downgrade (not work)
6. finally - changing TV...(not work)
So, please let me know if you found any other solution.
I personally tried on my ps3 slim but by doing the same thing repeately my ps3 hard disk fried. I just bought new one but still the same.
Thanks
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I haven't had any issues since. I believe the VGA reset worked.
Thanks
댓글 달기
The ps3 hdmi slots are starting to fail with age its not the cpu heating. After doing a teardown with cleaning and repaste I have confirmed that the problem is with the hdmi port corroding and becoming lose.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
chelcee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 21
전체 시간: 2,050
