주요 콘텐츠로 건너뛰기
Announced in October 2013, The Nikon D5300 is an upper-entry-level DSLR with a 24Mp DX-size sensor.
48 질문 전체 보기
"Zoom Out /? " Button is unresponsive.
Zoom Out / ? Button is automatically pressed even without touching. When double pressed of pressed hard it keeps responding neatly for 5 mins tops. and after same problem. Do I have to replace the back panel key board or any repairs can done by myself? Please help me out.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
가장 유용한 답변
it is most likely that there is dirt or something causing the button to stop working or to start working randomly of it own accord. you'd need to remove the back cover to expose the button contacts and give them a good clean, worst case scenario you'd be buying a rear cover button flex cable fpc.
it can be a fiddly job with screws hidden all over the place, there is no guide on iFixit to do this but there are guides for similar models like the D5200.
follow this guide to removing the back cover, once you have the back cover off its a pretty simple job to remove the ribbon cable and clean or replace.
Nikon D5200 Motherboard Or Camera Back Replacement
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Amila Yohan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,048
