주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone reboots into recovery mode even after restore
Weird problem that i have been encountering with my iphone 6. Every time i turn my phone off, it reboots into recovery mode. So i restore the phone and when it is freshly restored, it still reboots to recovery mode! i really don't know what to do except to never turn my phone off now.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Is the computer recognizing the phone?
Yes, the computer recognizes the phone and I tried multiple computers
Hello? You still there, has the problem been resolved?
댓글 달기
답변 2개
가장 유용한 답변
try to restore it in (DFU) mode by following these steps:
*before that If you see the battery charge warning, let the device charge at least for 15 minutes
1. disconnect usb cable from the iPhone, but leave the
other end connected to your computer.
2. turn off your iPhone by pressing and hold the power button for a few seconds
until the red slider appears, then slide the slider. wait for the device to turn off.
If you cannot turn off the device using the slider, press and hold the
power button and home buttons at the same time. when the device turns off,
release both buttons.
3. while pressing and holding the Home button, reconnect the usb cable to the
device. The device should turn on.
4. keep holding the home button until you see the "Connect to iTunes" screen.
as soon as this screen show up release the home button.
6. then use itunes to restore the device.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Still happens even after the dfu restore. Thank you for attempting to help :)
댓글 달기
Try rolling back the OS from iTunes on the computer and then re update from the phone then see if the problem persists
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Saleem 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 187
