주요 콘텐츠로 건너뛰기
American Edition released in 2013, identified by model number X502CA
11 질문 전체 보기
Stuck in bios mode after updating to windows 10
So yesterday I was updating my computer and it was downloading windows 10. It got all the way to 100% before it froze for about 2 hers. When I restarted it, it immediately went to Aptio Setup Utility. I have tried everything mentioned. Taking it apart, turning it on and off again, enabling and disabling you name it. Before updating my computer there was literally nothing wrong. Now it seems Im &&^&@@. Has anyone else had this issue when updating?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Go on another working computer and make a Windows 10 install/recovery media by going to this link and following the instructions
https://www.microsoft.com/en-us/software...
Insert the disk into the computer and boot up. In the bios, go to the boot tab and select the usb drive under boot override.
You should be booted into the windows recovery disk. Do not remove the disk. Go to repair my computer and select automatic recovery. If that does not work, then you will need to perform a fresh install.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yup .... that's the only real way
댓글 달기
귀하의 답변을 추가하세요
Frank Rojas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 962
