주요 콘텐츠로 건너뛰기
The Samsung NX1000 is a digital smart camera that was released April 2012
22 질문 전체 보기
I can not remove the native objective lens. lens is blocked.
I can not remove the native objective lens. I press the removal button, the lens is not removable. Lens is blocked.
Не могу снять родной объектив. Нажимаю кнопку снятия, объектив не снимается.
Update (12/08/2016)
It is not simple. I have to unscrew the lens before. And I know how to unscrew. However, already half a year can not unscrew the push of a button. I can just strip the threads by following your advice.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Press the button, then rotate clockwise or counterclockwise. Simple.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
You must hold down the button down as you rotate the lens. I do not see how it can be blocked, please explain how it is blocked.
I have a similar problem. Camera indicates Lens error oo when power on. Problem with the lens is that the zoom barrel will not turn. I have followed the advice above with regard to the small button and then trying to turn the barrel of the lens but to no avail. I think fffosrab has the same problem, but is just describing his fault as blocked rather than locked or jammed. Watched a video of opening up the lens but not sure I want to do that...
댓글 달기
귀하의 답변을 추가하세요
fffosrab 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 93
