주요 콘텐츠로 건너뛰기
Announced on October 16, 2014, the iPad Mini 3 is the successor to the iPad Mini Retina (now known as the iPad mini 2).
115 질문 전체 보기
iPad Mini 3 white lines showing across two thirds of the LCD
Hello everyone.
I have received an iPad mini 3rd gen. from a friend for me to fix. According to him there are white lines showing up on the lower 2/3 of the screen. Apparently he was using the device normally, when suddenly in the evening those lines appeared. He always handled the device carefully, but the warranty has expired a few months ago.
I now opened up the device, and reseated the LCD connector, allthough it did not help. Is this a common issue and is there a way to fix it, or is the replacement of the LCD itself the only solution here? I've included a picture of the issue.
Many thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
If you've tried reseating this it will most likely be LCD damage. Plug a new one in to test it
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Agree with Reece, this is a LCD fault and replacing it will solve the problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Daniel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 182
