주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Homebutton is stuck but sensor works
Hello,
My homebutton of my ipad air is stuck, i can't press it anymore.
But when i press really hard than it works , what is the problem then is it the homebutton self or the cable with the sensor?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
did you tried doing a hard restart on ipad . see if that help . just press the power key and hold for like 30 sec . thanks
That is Unfortunately not a solution for me because i can't click anymore on the homebutton it is not the software , but the hardware. thanks anyway for the suggestion
댓글 달기
답변 2개
선택된 해법
It will be the home button ribbon most likely. May need the plastic and rubber seal replaced around the home button, it is it getting stuck under the screen. You need to open this and check it out.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
I always try everything I can on iPads before I open them, since opening them almost always means a new screen.
Try cleaning the power button out with 99% IPA. Give it a good soaking and scrubbing. You won't hurt anything that isn't already hurt. If that doesn't fix it, its most likely just the glue on the bracket working loose after years of use. If you are pressing down on the button and it doesn't "feel right", its a safe bet that its just the bracket. It also could be that the bracket isn't lined up quite right because of a drop. It happens.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Sander Messiaen 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 1,732
