주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
Why wont my PS4 turn on?
So I recently unplugged my PS4 in order clear the fan as it was becoming very loud to the point where gaming was unbearable. After hoovering all of the dust out for my PS4 and returning the battery to it's position I attempted to boot up my console and the light stayed on for around 2 seconds and instantly cut out. I believe it may be because I hoovered it but would like to know if it can be repaired, Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
The first thing to check is that you have the APU clamp on correctly and that the screws are tightened down fully. Most of the time when it turns on and back off after you've had it apart it's because the clamp isn't tightened all the way. I've seen a lot of these clamps installed upside down as well.
If none of that works you could always try the washer fix.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi there,
Did you disassemble the console down to the motherboard in order to clean it? Because it sounds like the console may have been put back together incorrectly, or by running the vacuum over the board, you may have knocked off a component. Could you elaborate about what exactly was done to the console when you cleaned it?
I'd love to help you, I fix these things all the time!
-Samantha
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I only to the power supply out of my console in order to reach the heat sink. That was the only component I took out. :/
Then I'd suggest taking it back apart and examining the connections, because what you are describing to me makes me thing something isn't plugged in properly, or a cable was damaged when it was removed. It's easy to do, and that is not meant as an insult.
Give it a shot, and let me know!
Thanks! Is there a chance it is a faulty power supply or wire? Or could it be the APU?
댓글 달기
귀하의 답변을 추가하세요
Jamie Cain Hendry 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 91
