주요 콘텐츠로 건너뛰기
모델 A1046 또는 A1095 / 1280x854 스크린 해상도
118 질문 전체 보기
"Not Charging" in spite of new battery
Hello,
my PowerBook G4 15" Aluminium 1,5GHz shows "Not Charging". I already replaced the battery and reset PRAM and PowerManager.
Sometimes it says "Calculating" and went down to 3% but now it has got 39% but it always sais "Not Charging".
Is there anything I can do?
Thx and Mandy Regards,
Juliane
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
This is a tough call without having multiple batteries to use for testing. I always suspect the battery first, since it's generally the most likely problem. There are a lot of flaky batteries in the world, so it may be that your "new" battery is not actually good. I would have it swapped out before doing work on your computer, just to see. Also, how is the behavior of your old battery? Does it behave similarly, or does it charge like you would expect it to (although of course it probably doesn't hold much of a charge, which I assume is why you replaced it)? If it behaves like you would expect a battery to, then that points to your new battery having a problem, and if it behaves strangely like the new battery, then your laptop may have an issue.
I'd Google "Coconut Battery" and download it, and see if it shows that it is charging, and verify the capacity of the battery is what it should be. I would also make sure to leave the battery charging in the computer overnight. Sometimes batteries that have been sitting for an extended period take a while to "wake up" and normalize themselves.
It's conceivable that the battery connector inside the computer is faulty, or that you have a bad DC-in, but that's rarely the case in a specifically battery-related issue, especially if your computer works fine on AC power, and I'd really explore testing the machine with other batteries first if possible.
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
I replaced the battery because of the "Not Charging" problem and the new one behaves similarly. The problem appeared suddenly.
Coconut Battery sais (for the old battery):
Current Battery Charge: 1037 mAh
Maximum Battery Charge: 2636 mAh
39% (the same value as hours before)
Current Battery Capacity: 2636 mAh
Original Battery Capacity: 4400 mAh
59%
Battery-Loadcycles: 192
Age Of Your Mac: 125 Month
Charger Connected: Yes
Charging: No
It doesn't charge over night but I can see the orange light all the time.
Are two batterys enough for testing?
What are the readings on the new battery?
Current Battery Charge: 777 mAh (17%)
Maximum Battery Charge: 4266 mAh
Current Capacity: 4266 mAh (96%)
Original Capacity: 4400 mAh
Battery Load-Cycles: 1
Battery Is Charging: No
Hmmmm...the batteries appear to be OK from what you've posted. If the batteries behave the same, the one constant is the computer, so unfortunately I'd have to guess your computer has developed a hardware problem. I would start with the battery connector, because it's cheaper and easier to swap out, but honestly the problem in these situations is more often the DC-in.
It may also be worth trying another AC adapter if you haven't already. Is it the same AC you used when the machine was working, and is it 65-watt (15" PowerBooks are best used with 65-watt ACs, since they draw a fair amount of power)?
good answer and follow thru +
댓글 1개 더보기
댓글 달기
There might be some software updates that are required.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
To charge a battery and show accurate battery readings? I seriously doubt it.
Not on this Powerbook model, but in Macbook Pros that came with the older "straight type power connector," using the newer chargers with the "L" shaped connector results in the battery not charging. The solution is a firmware upgrade downloadable from Apple. I just can't find its location in the Apple website right now.
댓글 달기
귀하의 답변을 추가하세요
Juliane 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 5,489
