The Error Code 6A02
Hi, I have a 1999 Volvo S80, 2.8L engine. I'm getting the error code 6A02. How do I resolve this?
좋은 질문 입니까?
좋은 질문 입니까?
@jeffwashington , Info. from volvoforums.org.uk Chris_Rogers
If the central electronic module (CEM) detects a high signal from the lock position sensor 15 seconds after locking, diagnostic trouble code CEM-6A02 is displayed
Possible source:
-The lock has stuck in unlocked position
-Open circuit in lock sensor signal wire
-Lock position sensor signal wire short circuited to voltage supply
-Relay fault
-Open circuit on relay supply/defective fuse
-Fault in locking motor circuit
-Fault in rear electronic module (REM).
Fault symptom[s]
-A door does not lock / open.
Link to Volvo forum below. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 16
전체 시간: 2,175
