주요 콘텐츠로 건너뛰기
Cobra 29 LTD Classic. 2-way 40 channel CB radio. Features antenna warning indicator, SWR calibration, instant Channel 9, PA capability, dimmer control, switchable noise blanker and RF gain.
8 질문 전체 보기
keys 4watts no forward swing
cobra 29ltd classic keys 4 watts no forward swing.new mic new final new ic chip tda2003 new driver
Update (12/21/2016)
I don't know about a d104 but the d11 has been removed by me it has no modulation so it will not swing forward
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
If it is not ic3 more than likely it will be ic1 pll chip .have had several with key up but no modulation output and it turns out to be the pll chip.
have you tried a different microphone
yes mic was good. I got it tr17 shorted thanks
댓글 달기
답변 1개
Was the D104 diode clipped or removed? If not, remove the whole diode... If this is not removed, you won't get full modulation or watts. It must also be peaked to match the new driver and final.
This is just off the top of my head without you providing final and driver information, also assuming you upgraded the CB.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
mark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 907
