주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
904 질문 전체 보기
Volume stuck at max
I have a 80GB iPod Classic and the volume is stuck at maximum. I can use the wheel and the display shows it going up and down but the volume is always at max and changing the volume limit doesn`t do anything. I have tried restoring it and resetting it several times and nothing makes a difference.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hi,
Try plugging the device into an iPod dock or something that doesn't use the headphone jack to play the sound and test it there. If it still has the same issue it is possibly a damaged logic board. If you can adjust the sound normally there then it's likely an issue with the headphone jack / cable.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
T Radical 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 9
전체 시간: 462
