주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
disabled apple iPhone 5s
Greetings. I am new to this cellphone repair business. It is a hobby I took on to supplement my retirement pension income. One reason was because I took my iPhone 4s in to a repair tech 4 times for a mic repair. After 4 attempts at the repair, they finally told me the parts were out of stock. As I had the opportunity to watch the repair process, I decided to order parts from eBay and do my own repair. FYI, I am a very proficient diy person so I felt confident in my ability to do this repair. Successfully. Here is my question. My neighbour gave me his iPhone 5s to look at. His grandson tried to use it and screwed up the password. Now it is disabled and suggests trying again in 24 million minutes. Is this repairable? My neighbour is not the original owner of the iPhone. eBay purchase. It worked well when he first bought it. Any and all suggestions appreciated. Best regards, Lorne.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Greetings. This forum is starting to get interesting. If I can solve this problem. next I am going to try a water damaged 5S. Anyway, there is no backup for this problem iphone and by now the owner thinks he has forgotten the original password because her never wrote it down. Just my luck. Well, you know the old saying " if it was easy, anyone could do it." No guts, no glory. I shall persevere, and if this issue cant be solved, I will go on to something else. EBay is full of damaged iphones and I have lots of time. Hopefully, when I become a more efficient tech I can offer repairs that people can afford. Regards, Lorne.
댓글 달기
답변 3개
First check the imei on imei chechker site if it say find my iphone is ON you can restore it then you need the apple id of the previous owner then if it say OFF Just restore it no need activation process
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
The phone won't boot past the disabled screen. It's locked up solid. iTunes doesn't even recognize it.
Try to put it in dfu mode hold home botton n power same time then reallse the power after 5sec
댓글 달기
Put the iPhone into Recovery mode, Hold the power and home button together for 15 seconds> Release the power button and continue to hold the home button until iTunes logo appears or iTunes detects it. Once your in Recovery Mode you'll need to hit restore. Then iTunes will download the .ipsw for the iPhone and then it will restore
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is the worst scenario for an iPhone being disabled because it requires you to connect the iPhone to a computer to gain access to it again. Hopefully you made a backup recently to that computer, and hopefully you remember the actual passcode for the iPhone, otherwise you’ll have to erase the device and lose all data on it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
lornemx 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 784
