주요 콘텐츠로 건너뛰기
Eighth generation of the Mazda Protege.
49 질문 전체 보기
Heater only blowing out front vents, no heat to feet or defrost. Why?
Heater working but only blows out front vents. No heat to feet or defrost. Before replacing Heater Control Unit, it would only blow hot air from front vents- With this replacement it will now change from cold to hot and the air flow pressure does change from the front vents when changing the setting dial but there is still no air at all to feet and defrost. Can anyone tell me if there is a louver or valve that could be jammed and where to locate it? Or what else to try? Thanks!
Desperately Seeking Defrost :)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
4 댓글
Thanks for information. Looking for repair guide but would appreciate any info on where to find actuator or regulator. Cheers!
I have this problem too but with 2007 Chrysler Aspen. Had the blend door replaced and still no heat on the floor. As a matter of fact when you turn the knob to the floor vent it’s coming out of the top defrost panel b
I have a problem my 1999 Chevy Tahoe I cant get no heat or air to blow on feet all other vents work good except for the floor vent
2015 nissan rigue heat air only comes out of vents won't change to feet or defrost what do i replace to fix it
댓글 달기
답변 2개
선택된 해법
@nothotwheels , Most likely a AC/ Heat, blend door actuator problem. Actuator could be stuck, faulty, linkage off, etc. Could not find a link for the 1998-2003 protege but will post a link to show and tell in general where and what to look for. You may also find a reasonably priced repair manual online or at the local library to borrow. Good luck.
https://www.2carpros.com/articles/replac...
해당 답변은 도움이 되었습니까?
점수 10
3 댓글:
@lpfaff1 I know you like to ask for up votes but take a look at how that is working out for you and where your votes are actually coming from.
@mayer , I have noticed and appreciate and I also return as you suggest, what is also nice when poster's do post back accepting the answer and leaving a comment of their gratitude, it makes it feel worth while. I am still learning things about this site and with guidance from you and others things should be good. Mayer , have also noticed you have not been answering as much as you were before, busy at the office I suppose. If I am missing something here let me know! Have a good evening.
unplug battery for 30sec. it will reset
댓글 달기
it must be the cable thats hooked up in to that regulator that changes the direction of air
해당 답변은 도움이 되었습니까?
점수 3
2 댓글:
How do I located the heater control
The actuator typically on any vehicle has a flap that is controlled either manually by cable or by vacuum operated cable. It can be a labor intensive job to get to the heater box flap and then find a vacuum leak. See if you can get a shop manual on your make of car.
댓글 달기
귀하의 답변을 추가하세요
N Wiegand 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 24
7일 전: 204
30일 전: 938
전체 시간: 176,216
