주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
256 질문 전체 보기
Not powering on, not resetting,but charges battery
So ive looked through tons of possible answers for the Not powering on thing no one has been able to help me solve this and I just don't have money to take it in. Is there a possibility of me fixing this. I plugged it in this morning. It actually showed the percentage but once I hit Tue power button the screen shut off and hasn't turned on since. This was after it wasn't powering on already. I've dome the discharge method where you take the battery out and press and hold the power button for a few mins to discharge and then try again but nothing. I also have tried to do that and the soft and hard reset versions. Phone doesn't vibrate PR power back on at all. I charge it and there's no heat so its not a charging issue or bad battery. I can't figure put why the screen works but it won't power on. Any help guys? Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Does it shows battery charging sign? Like percentage?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
It's a board issue. We have repaired few dead Note 4 by replacing both the power ic chips on the board.
Thank you Amir! I'll go get it checked and replaced. Appreciate you taking the time to answer
댓글 달기
When I wrote this it showed 0% when I first plugged it in, then stopped snowing anything. It also still doesn't power on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
Elijah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 109
