주요 콘텐츠로 건너뛰기
Model A1213 / 8, 16, or 32 GB capacity
216 질문 전체 보기
my ipod wont come out of recovery mode
8 GB: ipod touch first gen still not working Ok so i did what u told me to do and that was to hold the home button and it said ipod in recovery mode must restore then i tried restoring it and it said unknown problem occcured in 1601. do u have any suggestions.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
What about error (1)???
댓글 달기
답변 6개
가장 유용한 답변
Error 1601 refers to an issue with the iTunes software on your computer. See this Apple Knowledge Base article for details and recommended solution:
http://support.apple.com/kb/TA38633?view...
Also, if you are on a Windows machine, have you changed/added/upgraded any antivirus programs? They can interfere with communication between the iPod and iTunes. Try to disable any auto-scan features, at least temporarily.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I am getting this also. And one of the forums says to make sure there are no other USB devices plugged in. I wonder if this includes my USB mouse?
Another thing I read that can cause the error is a dead battery and I certainly hope charging still works when restore doesn't.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
happened to my buddy i helped him solve it by...
first updating his itunes.
secondly if ur using windows xp go to control pannel go to apple moblie device support and repair it worked for me.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
shut down your firewall for a few minutes also any other security that you may have this will work I have been trying for hours I read this is tried it and it works
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I am having problems, but my error is (1). Any help???
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have the same problem, My Ipod is brand new, Charged turned on and receieved a message to update and then it crash and now in recovery mode with a error of (1) Any help This is for 1st generation. Had in storage for grandchild. Thanks
댓글 달기
I’ve learned that this can happen if your iTunes version is too high because after a certain version it won’t let you restore certain devices
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
PAUL OR COLIN LEYTON 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 6,373
