주요 콘텐츠로 건너뛰기
Hard drive compatibility between Toshiba models
Which other models of Toshiba laptops would allow me to use my existing Hard Drive without reloading software?
Ideally, I would install my existing drive into another laptop, turn it on and business as usual, (IE. be able to use it without too much configuring and no re-installation of operating system and other software).
My Toshiba A75-S231 is, (and always has been), an over-heating nightmare. Due to the design of the cooling system, (fans, air ducting and processor location), keeping it from clogging up with dust and over-heating is impossible.
When that happens, I have to expose those components to clean them. Over-heating stops until enough dust collects again. Sounds simple right? Not even remotely easy.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
The Satellite A75-S229 looks pretty close. You *might* be able to upgrade the processor using yours.
I would highly recommend Sysprep if you're doing this with a Windows machine. Sysprep is a good friend.
Unfortunately, Toshibas have a tendency to run hot. That is a pretty common complaint across the board with their laptops. Older enterprise grade Dell and HP laptops will usually cost comparatively and run cooler.
For those you would be looking for a Latitude or EliteBook. Both of which have excellent documentation!
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Michael, I'll check out Sysprep also. This is my LAST machine still running Windows XP and I desperately want to keep running that OS and the installed applications.
댓글 달기
귀하의 답변을 추가하세요
Steve 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 71
