주요 콘텐츠로 건너뛰기
This guide contains links and information to help users repair a Craftsman 16 gallon Wet-Dry Vacuum. Model #113179930.
How do I find replacement front casters for vacuum cart?
I'm trying to fix the front casters on a cart for a Craftsman 16 gallon wet/dry vacuum. The vacuum is model #113179930. Sears has a very helpful exploded view diagram for the product:
http://www.searspartsdirect.com/model-nu...
The casters I need are #23, Parts #: 73237. However, it seems they're no longer available, at least from Sears:
http://www.searspartsdirect.com/part-num...
Sears no-so-helpfully suggests: "The manufacturer no long makes this part, and there's no substitute part. If you choose to purchase a new product, please visit www.sears.com"
The current casters I believe have a completely missing roller bearing and therefore no longer will stay upright:
The casters slide into these attachments on the front of the vacuum cart:
Any advice to:
1) Find the exact replacement part
2) Find a suitable replacement I can install with the existing mounts
3) Come up with an entirely new wheel and mount system to pull wheels back on the front of the cart.
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
@luke give us some measurements. Shaft diameter and length as well as caster diameter will help us to help you:-)
Try www.CasterHQ.com for their grip ring stem casters. They were the cheapest online and shipped right away.
댓글 달기
답변 6개
선택된 해법
@luke , Luke Soules , If you have an old caster assy. take it with you to hardware/surplus store to compare with what they have in stock as they may have a replacement. Posted a few links below for replacement stem casters. Good luck.
http://www.homedepot.com/b/Search/N-5yc1...
https://casterconnection.com/casters/ste...
http://www.faultlesscaster.com/page.php?...
이 답변이 도움이 되었나요?
점수 5
댓글 달기
Hey luke, the cheapest casters I have found are from source 4, and they also have a guide for measuring them to know you're getting the right one:
https://source4industries.com/blog/how-t...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hey Luke,
Checkout this link to CasterHQ, they have a huge selection of 7/16” grip ring casters available with different wheel materials.
https://www.casterhq.com/Grip-Ring-Stem-...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi Luke,
I guess this is an old post, but I rebuilt my vacuum with wheels from www.castercity.com
Better than amazon, but a little more expensive.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I know this is an old post but maybe someone will find it useful. I've seen a great selection of casters at https://bandcip.com. For your particular application I would search in the stem caster category which can be found here: https://bandcip.com/product-category/cas...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Also checkout CasterHQ.com as they have the largest selection of casters and wheels online with really good prices!! If you call them they have alot of specialty casters and custom casters and wheels for unique applications, maybe one for this application. Thanks! Good luck!!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Luke Soules 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 1,102
