주요 콘텐츠로 건너뛰기
Install SSD HD in PowerBook G4 1.5?
PowerBook G4 1.5 12" has a Fujitsu MHT2080AH 75GB HD that is failing.
Can an SSD HD be installed in the Powerbook?
If so, what specs do I need to be aware of?
Will a KingSpec T-60 SATA III 3.0 HD work?
Does it need any kind of adapter? or spacer?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
No. Your machine uses an Ultra ATA/100. Even trying to find a new one of these will be very difficult (I've looked and have not found one yet, only used.)
update - here's a new one: http://www.newegg.com/Product/Product.as...
http://www.everymac.com/systems/apple/po...
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Does it matter if replacement HD is more than the original 80GB?
Will ATA/33, ATA/66, ATA/100, and ATA/133 work with Ultra ATA connection?
If drive is only listed as PATA/IDE, is there a way to tell if it is Ultra or other faster ATA speed?
(ATA/33, ATA/66, ATA/100, and ATA/133)
No, but I would stay under 2TB. The last limitation I remember was on G4s and as 120GB.
댓글 달기
Actually, if you are willing to build your own IDE drive you can do so as follows:
# Buy an mSata of the size you need. mSata’s are miniature SSD Sata drives https://www.amazon.com/gp/product/B07GZF...
  1. Buy and IDE to mSata converter in a case form https://www.amazon.com/gp/product/B01GRM...
  2. Put the two together and you have a SSD IDE drive
  3. Find instructions for installing an IDE in the 12” power book and away you go.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
dstx 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 13
전체 시간: 1,249
