주요 콘텐츠로 건너뛰기
WD My passport 500gb not detecting showing unallocated 650gb
I'm a computer hardware professional. My WD My passport 500 gb is not detecting showing unallocated 650gb I Tried all kind formatting the drive. It shows unable to format. How to troubleshoot and what component will be the problem on hardware so that I can service myself?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
First, open disk management. Find your disk in that list. Once you've found it, right click and hit delete volume for each partition on the disk. Once you've done this, the entire drive will become unallocated. Right click on the volume, and select new simple volume. Once this is done, it will ask you format it. Format it to NTFS. I hope I was of assistance to you.
해당 답변은 도움이 되었습니까?
점수 3
댓글 9개:
I did that and didn't work. When I create the partition it creates only 80gb in diskmanager and others unallocated unable to create or format the unallocated partition. And I used wd formating software, acronis disk director and partition magic tools software too it didn't work saying cannot format cycle redundary error
Do not create any partitions. Make all partitions unallocated, the create new simple volume from that single partition. You cannot format unallocated partitions.
Why did you repeat it? I read it the first time.
Did it work?
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
Anzar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 3,433
