주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
iPhone 5s stays at 1 percent battery and never charges up.
I have an iPhone 5s and I changed the entire dock connector part, because the jack connector was giving crackling noise when I would plug my headphones.
After that, the phone stopped charging.
So what I did is:
-Put a new battery in
-Put back the old dock connector part
-clean all connector and the motherboard with isopropanol 99%
Nothing solved the problem. The percentage is still stuck at 1% and the phone goes off 30 seconds after I unplug it, and when I plug it to my computer again, the screen stays stuck at the red battery screen, even after a few hours. However, the phone DOES get recognised by the computer. The only thing not working is the charging up.
The only way I can use my phone again is to put it in DFU mode and Restore.
What could be wrong in my case?
PS: Some screws are missing on my dock connector part, can that prevent things from working?
EDIT: this is what happens when I unplug the battery and connect the iPhone to my Mac:
https://www.dropbox.com/s/oti1otfx1q0cfv...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Using the guides to give you specific details on how to do this:
  1. Unplug the battery
  2. Perform a hard reset on the device without the battery
  3. Plug the battery back in
  4. Perform a hard reset again, this time with the device on
  5. Calibrate the battery, instructions can be found in the battery replacement guide.
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Probably a bad U2 Tristar charging ic if restore does not work.
Also about screws missing on charging dock it should not effect charging as I test charging flex ribbon cables without fully installing them to see if it is charging the battery.
Thanks for your response. Somehow I managed to get it to work after having unmounted and remounted the entire piece.
The battery charges up to 100% as normal, and charges back up again when I replug it after use. However, once it reaches 0% and turns off, it's stuck on the red battery icon and doesn't charge up. I tried to restore again. The restore starts working but it gets back to that red battery icon again...
So the iphone charges up when it's on but doesn't when the battery is at 0%. Does that look like the IC chip being faulty?
Thank you
This is what happens when I unplug the battery and connect the phone to my Mac:
Yep. I'd get the U2 Tristar charging IC replaced because it is a symptom listed on here:
https://www.mendmyi.com/blog/2014/06/has...
댓글 달기
귀하의 답변을 추가하세요
Alex222 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 19,434
