Why does the record player play slowly
the record part of this machine plays the records slightly slower than they should be played. I am curious if there is a repair option for this, and where to look? Thanks.
좋은 질문 입니까?
좋은 질문 입니까?
I had this same problem. Turns out that I didn’t have the lid open fully abd the vinyl was rubbing slightly on the lid!
해당 답변은 도움이 되었습니까?
You are amazing thank you so much I was literally freaking out over this. Super helpful my guy thanks again
I'm not sure how old yours is, but I'm guessing since it has a disc player it's pretty new. I have a different brand player, produced in the last ten years, that slows down often. To adjust the timing on it there is tiny mechanical part on the inside that you can insert a jewelers flat head into and lightly turn to adjust the timing. I usually pull up a song on YouTube and use it to compare to the record. However if you adjust it while a records on you risk scratching.
Mine slowed down so often I drilled holes in the bottom to access it without tearing the player apart everytime just to adjust it. After all I can't listen to The Bee Gees slowed down
-Liz
Here's an image of the part, I have three, one for each speed.
해당 답변은 도움이 되었습니까?
no only a motor underneath. no place for adjustment. sad
24 시간 전: 0
7일 전: 10
30일 전: 23
전체 시간: 11,547
댓글 1개
I just saw this post! This was my issue as well. Thank you!!!!
mbebower 의
