주요 콘텐츠로 건너뛰기
Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
97 질문 전체 보기
Touch ID not working after screen replacement
So I attempted to replace a broken screen on the iPad mini 4. I successfully replaced the screen and home button but then realized the Touch ID isn't working. Of course, after the fact, I read how this can happen. I removed the home key and replaced to new screen but a small cable tore and unsure what exactly it does and how to repair. I took a picture but unsure how to upload. It's a small square to the left of the home key.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Based on your description (I don't see pictures), you tore the delicate home button connector, and unfortunately, there's no way to replace this and retain TouchID functionality. The only way to regain TouchID functionality is to get a paired logic board/home button assembly. For security reasons, each TouchID sensor is binded to a logic board during manufacturing, so you cannot replace one or the other without replacing both.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Even though the home button still works? Any idea how much that costs?
I believe that the home button uses POGO style contacts to make a connection, and that only TouchID data travels through the ribbon cable. iFixit does not have any replacement parts for this particular model of iPad, but it is not a cheap or easy repair (>$300).
Ah, okay. Thank you for your help!
댓글 달기
가장 유용한 답변
This was torn off from the broken iPad
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Brenda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 14
전체 시간: 4,932
