주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
iPhone 6s plus unexpected shutdown and not getting turn on
hello guys,
My phone died the other day unexpectedly, although it was charged like 60 percent.
First i tried force restarting it. but it didnt help. then i plugged it to be charged. Nothing happens as i plugged it to power. however, after like six hours it turned on by itself. next day it again died and again after some hours it just turned back on. this has happened to me like four times by now.
i have tried force restarting it. i have reset the phone using the phone when phone was on. i have recovered it using itunes when the device was working. but non of this has helped.
i should say i has not been damaged physically or has not been wetted.
When for the first time it turned off, my cars AUX jack was plugged to the device's headphone jack.
Guys i dont have access to apple stores or their repair centers. so please help me what could have caused this problem.
thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 3개
there has been a recent issue with iphone 6s's that make them randomy shut off. What percent does it die
Try to change ur battery..
To Robert Hayek,
Well, first time it happened when the phone was 60 percent charged. Then again it happened while it was fully charged.
댓글 달기
답변 2개
가장 유용한 답변
Morshed M , Go to the (iPhone 6s Program for Unexpected Shutdown Issues) Link below to see if you qualify in the replacement program. Good luck.
https://www.apple.com/support/iphone6s-u...
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you L Pfaff,
I checked the link, unfortunately I wasn't included in the program.
But it was really helpful. Thank you
댓글 달기
I had the same issues i replaced the battery and did a factory reset though iTunes and that worked for me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Morshed M 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 8
전체 시간: 498
