주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Help! Unable to boot from any disk after Sierra installation
Hi all,
So, I finally upgraded to Sierra and everything was fine the first couple of hours. I closed the lid only to realise 3 hours later that the mac never went to sleep but was instead running the fan full throttle. I had to do a hard reboot and to my horror saw that the computer stalled at the white start up screen (with the apple logo).
Additional info that might be relevant: A couple of years ago, I replaced the CD-drive with a SSD drive for applications and OS. I still have the original internal HD installed as well (but without OS of course). I have installed new 8GB RAM as well.
So far I've tried:
- Disk Utility in recovery mode (claims all disks are fine)
- Safe boot (still stuck at white screen)
- Reset NVRAM
- Reset SMC
- Single user file consistency check (fsck -fy) – showed some errors first time, but after running again it claims that everything's fine.
- Sierra reinstall three times (but of course the download itself might be corrupted)
- Booted from an external drive with a backup partition. Guess what? Stuck at white screen.
When I boot the computer in safe + verbose mode, there are a couple of errors that might interest people who know more than I do: the picture of the screen is attached below. The "master-entitled process" that was cropped off the image is named 'launchd' (1).Verbose photo
I have no idea whether this is physical damage, boot sector confusion or something else? Please help.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Thank you for the suggestion! I did try that a couple of times early on, but to no avail.
I just now fixed it by creating a bootable disk with Terminal on another mac. I could then boot and wipe my faulty boot drive using Disk Utility and do a clean install of Sierra.
Terminal command for creating a bootable drive is (make sure the installer is in /Applications):
sudo /Applications/Install\ macOS\ Sierra.app/Contents/Resources/createinstallmedia --volume /Volumes/Untitled --applicationpath /Applications/Install\ macOS\ Sierra.app
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
The white screen would indicate to me a hard drive or hard drive/IR cable failure. Try booting to your repair partition by holding down the option key on start up and see if you can select the repair partition select it and see if you can boot and run Disk Utilities.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Have you tried reinstalling OS X using Internet Recovery?
While the computer is off, hold Command+Option+R while turning it on.
It should boot into Internet recovery if you have an active connection.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I finally got in after a recovery boot and reloaded Sierra, so far so good. Thanks for all the responses
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gaspard Winckler 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 718
